Superbooth 2021: Endorphin.es gets into 1U modules
2021-12-9 14:12| ·¢²¼Õß: hongyan6| ²é¿´: 570| ÆÀÂÛ: 0
ÕªÒª: Superbooth 2021: Endorphin.es gets into 1U modulesEndorphin.es is stepping into the 1U Eurorack space by converting Golden Master, Milky Way and Cockpit into the horizontal format. All three modules h ...
Endorphin.es is stepping into the 1U Eurorack space by converting Golden Master, Milky Way and Cockpit into the horizontal format. All three modules have been redesigned to fit the 1U format and take advantage of behind the panel connectors for integration with the Audio IO board in Intellijel cases.
ADVERTISEMENT
Golden Master 1U
This is a multiband processor which is unusual in Eurorack and wants to sit at the end of your signal chain. Behind the panel, it has an AUX In and MIX Out for chaining with other Mix Bus compatible modules, and a 6 pin balanced output for the Intellijel IO outputs.
Milky Way 1U
A fabulous stereo FX module featuring 16 different algorithms with panning and the ability to crossfade input signals via CV. It also has a MIX Out bus connector on the back.
Cockpit 1U
A compact 4 channel stereo mixer with sidechain ducking all ergonomically laid out for 1U. It has very handy scribble strips! Channels 2, 3 and 4 now have dual mono inputs while channel 1 is purely stereo. It too has the MIX Out, AUX In and 6 pin balanced output on the back.
Intellijel 1U
Endorphin.es has definitely embraced the Intellijel 1U format almost to the point that it might put off other users who have 1U in a non-Intellijel case or form. However, for Intellijel 1U users these are well designed and offer a way of approaching these tasks differently.
These modules will be available in October and cost
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
