Fugue State Audio NANDroid Fugue State Audio NANDroidHere¡¯s an experimental synth with a delightfully geeky edge to it. According to the developer, NANDroid is a noisebox synth with four square wave oscillators feeding NAND gates ¨C hence the name. Those gates then feed another gate. There¡¯s also a filter, a bunch of modulators such as LFOs and a delay effect. NANDroid produces some pretty wacky, noisy sounds ¨C if you¡¯re into experimental sound design and unusual synthesis concepts, be sure to give this one a try. NANDroid is a VST3 plug-in for Windows (64 bit). |
