Nembrini Audio Black Distortion
2021-12-5 09:01| ·¢²¼Õß: 4052090| ²é¿´: 1149| ÆÀÂÛ: 0
ÕªÒª: Nembrini Audio Black DistortionNembrini Audio Black DistortionIt¡¯s easy to see which classic pedal Nembrini Audio is bringing to your DAW with this awesome freebie. Black Distortion is of course base ...
Nembrini Audio Black DistortionIt¡¯s easy to see which classic pedal Nembrini Audio is bringing to your DAW with this awesome freebie. Black Distortion is of course based on the ProCo RAT2 distortion pedal, a timeless classic. The developer says that it¡¯s responsive and versatile and can be used for any style from rock, blues and punk to jazz. Three simple controls (drive, filter and level) and a bypass switch ¨C those are the tried-and-true ingredients of your new ¡°go-to distortion pedal¡± (Nembrini Audio).
Black Distortion is available for macOS 10.9 or higher (M1 supported) and Windows 7 or higher in VST, VST3, AU and AAX formats. There¡¯s also a version for iOS, which is also free and available in the App Store.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
