New Audio Plugin Lets You ¡®Debird¡¯ Your Recordings Boom shared this video demo for Debird, an audio effect that they say removes bird noises from your recordings with ¡®surgical precision¡¯. The AI-based tool uses machine learning to identify and remove bird sounds from location audio. You can isolate and solo the bird sounds, and even dial in custom levels of ¡®debirding¡¯. Features: Remove bird noises in real time. Radically simplify and expedite your workflow. Super-fast processing of audio files. The advanced Machine Learning algorithm guarantees the most precise removal of bird sounds without audible loss of the desired sound frequencies. Use the built-in filters to choose frequencies you want to keep to exclude them from the removal process. Adjust the sensitivity to fine-tune the amount of removal. Isolate and solo out the bird sounds, if desired. Debird keeps learning on the job and will improve over time. |
