Mojave Audio MA-37: Mojave¡¯s take on the classic Sony C-37a
2021-11-22 08:11| ·¢²¼Õß: lanchong| ²é¿´: 1156| ÆÀÂÛ: 0
ÕªÒª: Mojave Audio MA-37: Mojave¡¯s take on the classic Sony C-37aMojave Audio has announced the MA-37 tube condenser microphone. The company says that its take on the classic Sony C-37a updates the origina ...
Mojave Audio has announced the MA-37 tube condenser microphone. The company says that its take on the classic Sony C-37a updates the original design with modern components for a rich, natural sounds that oozes musicality.
ADVERTISEMENT
Mojave Audio MA-37
With the new MA-37, Mojave Audio seeks to recreate the revered sound of the Sony C-37a tube condenser microphone. Released in the 1950s, the C-37a is often associated with the ¡°Golden Age¡± of Hollywood recording. But the MA-37 isn¡¯t an exact clone. While staying close to the original design, Mojave says that they¡¯ve made a couple of modern updates in terms of the microphone¡¯s components, workmanship and build quality.
Mojave Audio MA-37
Like the C-37a, the MA-37 is a high-headroom, large-diaphragm tube condenser microphone. It uses a special capsule design with an adjustable tuned acoustic chamber that lets you choose from cardioid and omnidirectional polar patterns using a mechanical shutter. The circuit is based on a single-stage tube amplifier with an EF806 tube and a Lundahl transformer. A switch on the external power supply provides three selectable options for the integrated high pass filter: flat, 100 Hz, and 200 Hz.
Mojave Audio MA-37
The high pass filter switch is located on the power supply
If you¡¯re after those ¡°Golden Age¡± vibes associated with the likes of Leonard Bernstein, The Wrecking Crew and Mel Blanc, but don¡¯t feel like selling your house for the vintage classic, the Mojave Audio MA-37 looks like a great modern alternative. It certainly isn¡¯t cheap, either, but if it sounds anywhere near as good as the original, it¡¯ll be well worth the investment.
Specifications
Frequency response: 30 to 18,000 Hz. +- 3dB. (¡°M¡± setting)
Bass cut: M flat
V1 -3dB at 100 Hz
V2 -3dB at 200 Hz
Sensitivity: -46 dBv referred to 1 volt per pa
Distortion: Not to exceed .5 percent at 134 dB
Noise: Better than 18 dB
Polar pattern: Choice of cardioid or omni; via mechanical shutter
Impedance: 170 ohms, floating. Recommended load 1500 ohms or higher
Power required: 115 or 230 VAC, 50 or 60 hertz; 5 watts
6 volts DC at 200 mA
140 volts DC at 1.5 mA. from dedicated power supply
Mojave Audio MA-37
The MA-37 comes in a carrying case
Price and availability
The Mojave Audio MA-37 is now available for USD 3499 (MAP).
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
