Audiority Dr Phase
2021-11-22 07:26| ·¢²¼Õß: 32679200| ²é¿´: 812| ÆÀÂÛ: 0
ÕªÒª: Audiority Dr PhaseAudiority Dr PhasePedal aficionados will recognize this classic instantly: Dr Phase by Audiority is of course an emulation of the classic MXR Phase 90, probably the best-known phaser ...
Audiority Dr Phase
Audiority Dr PhasePedal aficionados will recognize this classic instantly: Dr Phase by Audiority is of course an emulation of the classic MXR Phase 90, probably the best-known phaser pedal of all times. The plug-in¡¯s single knob lets you set the modulation speed. And Audiority has added a couple of very useful extras. You can sync the effect to your song tempo, adjust the pre and post effect gain and dry/wet mix, and activate vintage mode for extra vintage vibes. Sounds great on guitar and everything else!
Dr Phase is available for Windows 7 or higher (64 bit) and macOS 10.8 or higher (M1 supported) in VST, VST3, AU and AAX formats.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
