BLEASS Motion FX Multi-Effects Plugin Now Available
2021-11-21 11:14| ·¢²¼Õß: jewel| ²é¿´: 739| ÆÀÂÛ: 0
ÕªÒª: BLEASS Motion FX Multi-Effects Plugin Now AvailableBLEASS has released Motion FX, a new multi-effects plugin designed for sequenced modulation, for macOS Windows.Motion FX features 11 different effec ...
BLEASS has released Motion FX, a new multi-effects plugin designed for sequenced modulation, for macOS & Windows.
Motion FX features 11 different effects:
Low Pass Filter
High Pass Filter
Band Pass Filter
Volume
Pan
Pitch Shifter
Frequency Shifter
Ring Modulator
Warmth
Bit Crusher
Delay
Each effect has a parameter automated by the sequencer and can have one or more secondary parameters.
The Sequencer:
The sequencer offers 4 to 16 steps, each step has a value and a curve. You can set the value by touching and/or dragging the step and set the curve by tapping the curve icon at the bottom of each step. Curves choices are: Step, Ramp Up, Ramp Down, Ramp and Smooth Ramp.
Length controls the number of steps (4 to 16).
Resolution controls the duration (in bars) of each step. (from 1/32 bar up to 4 bars)
Grid snap: when set to ON, steps values snap to the displayed grid when you change their values.
Reset: resets all steps to their default values (default value depends on the current selected effect).
Amount sets the sequencer¡¯s amplitude.
Randomness sets the range in which step values are randomly chosen.
Smooth sets the interpolation time between steps.
Pricing and Availability
BLEASS Motion FX is available now with an intro price of $24 USD (normally $35).
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
