Master Tones releases The Stage Package: Analog Stereo Field Editor Plugins
2021-11-16 09:02| ·¢²¼Õß: 6986520| ²é¿´: 859| ÆÀÂÛ: 0
ÕªÒª: Master Tones releases The Stage Package: Analog Stereo Field Editor PluginsNew product from Master TonesProduct:The Stage PackagePrice:Introductory price $119(MSRP $159) - 25% OFFProduct Page:https:// ...
Product Page:https://www.master-tones.com/product/the-stage-package/
Description
Bring your sound to the next stage, literally. Numerous classic analog gears that work magic on the sound image, but with The Widener (TW) and The Deepener (TD), we make the magic available through your computer. Powered by Ariosa technology, The Widener expands the boundary of your sound to a whole new level, breaking the borderline of the stereo image with no phasing issue; The Deepener can easily alternate the depth of the center stage, creating an astonishing dynamic to your work. Combining forces, The Stage Package will change your perspective towards digital plugins and your music. Free full function 14-day trial version are available.
Features
• Two plug-ins: The Widener (TW) and The Deepener (TD)
• Expand stereo width image and modify sound source depth image
• EQ for the plugin to function only at certain frequency range
• Smooth functioning without any phasing issue
• Input/Output gains with reverse link
• Intuitive and neat UI/UX, easy to navigate
• Presets that help with fast mixing
• Highest supporting sampling rate at 96kHz (up to 192 kHz internal working sampling rate)
Audio Samples
• The Widener: https://soundcloud.com/mastertones/sets/the-widener
• The Deepener: https://soundcloud.com/mastertones/sets/the-deepener
Specification
Hardware Resources:
• Memory: 2 GB RAM or higher
• Display resolution: 1280 ¡Á 960px or higher
• Intel compatible or Apple Silicon CPU (M1), full native support (minimum 2 GHz recommended)
MacOS
• OS X 10.9 and above, 64-bit only.
• Plug-in formats: VST3, AU, AAX
• DAWs supported: Pro Tools, Cubase, Nuendo, Reaper, Studio One, Ableton Live, Logic Pro, FL Studio, and more.
Windows:
• Windows 10, 64-bit only
• Plug-in formats: VST3, AAX
• DAWs supported: Pro Tools, Cubase, Nuendo, Reaper, Studio One, Ableton Live, FL Studio, and more.
About Master Tones
We are a mixture of engineers, tech geeks, audio engineers, and musicians from Taiwan, all have a passion for creating great sounds. Perseverance and determination are what we share with the other great names across many industries. We are dedicated to making products that not only deliver high-end sounds but also help people to create touching acoustic experiences.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
