Scorpio: Synth Motion Engine for Kontakt by Artistry Audio Artistry Audio has announced the release of its new Kontakt instrument Scorpio, a next-level modern motion synth ready to push the boundaries of your music and inspire you in ways you have never imagined. Whether you want to keep things simple with the hundreds of presets or dive deep beneath the surface to sculpt something that¡¯s all your own, this instrument is packed with high definition sounds that are sure to inspire your creativity. Built in Kontakt, Scorpio loads up as one monolith instrument with a fully tagged onboard browser for its presets, effects and source sounds. It¡¯s simple to choose from the master preset tags and then quickly navigate to the type of sound that¡¯s perfect for your project. It¡¯s never been easier to create your own bespoke instruments and save them for one-click recall as you can name, tag and save your creations with just a couple of clicks. Scorpio features 50 multisampled instruments. 1 NKI with 200 master presets: 100+ core presets, 100+ effects presets. Sound categories: Cinematic, electronic, lofi, downtempo, organic, sound design. Creative XY macro controller, smoothly modulating the sound with a kaleidoscope of effects. Manipulate multiple layers of parameters, from tempo-synced sample looping to granular playback. Action Arpeggios, set each arp lane independently between 1 and 16 steps, allowing interweaving motifs and polyrhythms to be played with ease. Easily randomize any level of the instrument, from master sound sources right down to macro FX. 2.2 GB download (2.8 GB uncompressed samples). Requires the Kontakt full version 6.5.1 or higher. Scorpio is on sale for the introductory price of $89 USD for a limited time (regular $149 USD). Users of Origin X can use coupon code LOYAL10-1019X at the checkout to get an additional $10 USD discount. A bundle of Scorpion and the Origin X modern loop engine is only $178 USD during the promotion (regular $348 USD). |
