| Roland brings back the JX-8P and JD-800 synths with the new Boutique JX-08 and JD-08 Roland is exploring both its analogue and digital heritage with its latest pair of Boutique synths - the JX-08 and JD-08 - which emulate the JX-8P and JD-800 respectively. Released in 1985, the JX-8P was one of Roland¡¯s latest ¡®80s analogue synths, and was famed for its warm pads, shimmering chorus and bright textures. The JX-08 gives you all of this and more - new effects and a polyphonic sequencer for starters. Other additions include extended polyphony, two-part multitimbrality and dual/split modes. You get 32 presets from the original synth plus 100 new ones that are designed for contemporary styles. Roland JX-08 and JD-08 Designing your own sounds should be made easier by the inclusion of all the controls from the PG-800 programmer unit, which was released to complement the original JX-8P. You have 256 slots in which to store these. Jumping forward a few years, the new JD-08 is based on Roland¡¯s mighty JD-800, a beast of a digital synth from 1991. As it turns 30, the JD-800 is having a bit of a moment: Roland has already emulated it as a Zen-Core Expansion and plugin this year, and only last month, we made it clear that a hardware revival would be a good thing, too. The JD-08 certainly isn¡¯t a 1:1 recreation, but it does take the JD-800¡¯s four-tone structure, 108 waveforms and two-part multieffects and plonk them in a much smaller instrument. You even get a miniature version of the synth¡¯s huge control panel, with plenty of sliders, buttons and knobs for hands-on tweaking. Roland JX-08 and JD-08 There are enhancements here, too - expanded polyphony, a two-part polyphonic sequencer and other modern niceties. Both the JX-08 and JD-08 can serve as USB-C audio/MIDI interfaces, with full-size MIDI ports enabling easy connection to other hardware. There¡¯s an external clock input, too. As with previous Boutiques, these new models can be bus- or battery-powered and have a built-in speaker. They¡¯re also compatible with the optional K-25m 25-note keyboard unit. The JX-08 and JD-08 will be available in January 2022 priced at $400 each. Find out more on the Roland website. Ben Rogerson I¡¯m the Group Content Manager for MusicRadar, specialising in all things tech. I¡¯ve been playing the piano, gigging in bands and failing to finish tracks at home for more than 30 years, 20 of which I¡¯ve also spent writing about music technology. |
