Plugin Alliance offers the bx_masterdesk Classic ($149 retail price) mastering plugin by Brainworx as a FREE download until November 24th, 2021. bx_masterdesk Classic is typically priced at $149, but you can use the coupon code BX-FOR-FREE to get it completely free of charge at Plugin Alliance. IMPORTANT: bx_masterdesk Classic (currently free) is different from the bx_masterdesk plugin. It has fewer controls than the original. Thanks to BPB readers Christian H. and Ivan for the correction. I got bx_masterdesk for free during one of Plugin Alliance sales (with a $20 coupon), and it¡¯s quickly become one of my go-to plugins on the master channel. I actually have a mastering template in Studio One, and bx_masterdesk is one of the few plugins used in that template. The plugin features a streamlined interface that won¡¯t confuse users with unlimited control parameters and millions of features. Instead, it offers a streamlined 3-step workflow with intuitive controls and a dynamic range meter which will help you find the compression sweet spot with ease. The idea is to make it possible to master a song in under 60 seconds. bx_masterdesk includes a variety of mastering presets that are suitable for different music styles. Choose the preset that works best for your song, then fine-tune the available control parameters for best results. Of course, this isn¡¯t a substitute for having your music mastered by a professional mastering engineer. Still, it¡¯s helpful when you¡¯re mastering a demo track or when you want to speed up your mastering process. I often use bx_masterdesk as a reference tool for A/B testing my mastering chain against it. bx_masterdesk also takes advantage of Brainworx¡¯s signature TMT (Tolerance Modeling Technology), which simulates the slight variances of the hardware components in the software realm. Free Autotune VST Plugins Here¡¯s more info about the plugin: ¡°Brainworx¡¯ bx_masterdesk Classic gives you the sound of a complete high-end analog mastering system in one incredibly easy-to-use plugin. Dial-in professional-sounding masters in just 3 simple steps.¡± Hear the plugin in action in the demo video embedded below. bx_masterdesk is available in VST2, VST3, AU, and AAX plugin formats for compatible DAW software on Windows and macOS. Only 64-bit plugin hosts are supported. You¡¯ll need to sign up for a Plugin Alliance user account (valid email address required) to download and activate your free copy of bx_masterdesk. This is a limited-time offer that expires on November 24th, 2021. |
