Plugin Alliance launches Neold Warble tape modulator effect plugin
2021-11-8 08:19| ·¢²¼Õß: xuanwen| ²é¿´: 806| ÆÀÂÛ: 0
ÕªÒª: Plugin Alliance launches Neold Warble tape modulator effect pluginPlugin Alliance has announced the release of the Neold Warble plugin, a vintage tape modulation and lo-fi effect.With ease, it makes e ...
With ease, it makes everything you throw at it sound special, warm, and analog. Its three main effect engines can be used by themselves or in combination with each other, thus bridging the gap between ease of use and seamless versatility.
Neold Warble features
Authentic tape modulation block with wide-range Wow/Flutter plus individual Speed controls.
Comprehensive tone-shaping block with highly integrated Dirt, Age, and Noise parameters.
Hi-Cut and Lo-Cut filter section with individual resonance controllers.
Fast/Slow tape transport settings for changing global parameter behavior with a single button.
Mix controller to create the perfect blend of clean and warbly.
The plugin has an MSRP of $249 USD. You can purchase it for $129.99 USD with coupon code WARBLE-INTRO-12999 at the checkout until January 5th, 2021.
Warble is $99 USD to owners of NEOLD or Tone / Character plugins, ADA Flanger, ACME Opticom XLA-3, Brainworx bx_townhouse Buss Compressor, Brainworx bx_crispytuner, elysia alpha compressor, Shadow Hills Mastering Compressor (Green or Red), SPL Transient Designer Plus or Vertigo VSC-2. Log in to your account and simply add the Neold Warble to your cart to get the discount.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
