RESO: Dynamic resonance suppressor effect plugin by Mastering The Mix Mastering The Mix has announced the release of RESO, a dynamic resonance suppressor that helps you quickly identify and resolve resonances in your audio. Excessive resonances ruin mixes, giving them a harsh and unpleasant sound. RESO helps you identify which specific frequencies are causing problems. It also guides you on how much reduction is needed to dynamically resolve the resonance without making your mix sound thin. RESO uses smart analysis that gives you fast results. It features mastering grade filters for cleaner sounding mixes. RESO for Windows and Mac (VST/VST3, AU and AAX) is available at Mastering The Mix and from distributor Plugin Boutique, priced ¡ê49 GBP / $69 USD / 59.95 EUR. The plugin is offered at an introductory 15% discount until December 6th, 2021. Note that with a purchase at Plugin Boutique, you can also get Mastering The Mix¡¯s LEVELS plugin for free until November 15th, 2021 ($59.99 USD value). |
