Analog Waveforms Ds Is A FREE Decent Sampler Instrument By SampleScience
2021-11-8 07:35| ·¢²¼Õß: 6326750| ²é¿´: 848| ÆÀÂÛ: 0
ÕªÒª: SampleScience has released Analog Waveforms Ds, a FREE sample-based virtual analog synthesizer made for Decent Sampler.SampleScience had previously released Analog Waveforms earlier this year, a VST p ...
SampleScience had previously released Analog Waveforms earlier this year, a VST plugin built on the same samples.
They built this new instrument by sampling every basic waveform of a Dave Smith Mopho synthesizer note-for-note, so what you get are genuine analog synth tones.
Every sample is ten seconds long, so you get an authentic analog synthesis sound that decays and evolves as you sustain.
Here¡¯s a short overview of the instrument¡¯s features:
4 basic analog synth waveforms ¨C Pulse, Sawtooth, Triangle, and Saw-Triangle
Lowpass Filter
Delay and Reverb
Chorus and Phaser Modulation
Low-CPU Usage
The sounds are well sampled, and each waveform has multiple controls ¨C Attack, Release, Decay, Sustain, Pan, and Tuning. You can control the volume of each waveform to stack them in layers, allowing for some fascinating experimental sounds.
It¡¯s also got the usual chorus, delay, phaser, and reverb effects that you¡¯d expect from an analog synthesizer. Each of these effects has its own knobs, so you get complete control over them.
The overall interface is rudimentary ¨C it¡¯s just a collection of knobs and settings to adjust. While it¡¯s not fancy, it does get the job done, and the unpretentious aesthetic does have its own charm.
This virtual analog synthesizer will give you a ton of possibilities in terms of sounds. You can create everything from the simplest of leads to complex, evolving bass lines. It¡¯s easy to use and runs smoothly with low CPU usage, so running multiple stacked instances shouldn¡¯t be an issue even on older computers.
As this instrument was made for Decent Sampler, you¡¯ll have to download and install that first if you don¡¯t already have it. Decent Sampler is also free and available for Windows, macOS, and Linux in the VST/VST3/AU/AAX formats.
While there are no videos for this new version just yet, you can check their old Analog Waveforms video to get an idea of the sounds:
The download size for this instrument is 312 MB, and it¡¯ll take up 352 MB on your hard disk once unpacked. If you like their work, you can donate any amount of your choice to get faster download speeds!
What¡¯s best about this instrument is that all of the sample sounds are in the public domain and are available on the SampleScience website. So you¡¯re free to download the sounds and modify and manipulate them to your own liking!
Analog Waveforms Ds is a powerful tool for musicians and producers alike. It has a lot of flexibility and a ton of features. If you¡¯re looking for a FREE analog synthesizer plugin, Analog Waveforms Ds is a fantastic choice.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
