United plugins unveils Unichannel -includes 3 preamp types, 3 kinds of EQ, and 3 compressor types. Having a vintage gear collection in the studio is nice and inspirational but unfortunately, it is also time-consuming and expensive. SounDevice Studio's owner, Boris Carloff, knows this very well, as he has been collecting vintage gear for more than 20 years: "There is always something not working. From tubes to scratchy pots, from meters to noisy caps. And the units are so rare that you can hardly ever use them on multiple channels simultaneously." To avoid these limitations, we were inspired to create a solution that included the best of these devices into one plugin. The result is UniChannel. Complete vintage studio UniChannel delivers the warm analogue sound, but unlike its real hardware counterparts, it can be connected to every channel of your mix. You can also change the components with one click (instead of using a screwdriver or a patch bay). UniChannel has a preset for every occasion. And there are no ageing and broken components to maintain! 27+ plugins UniChannel includes 3 preamp types, 3 kinds of EQ, and 3 compressor types. That makes a total of 27 combinations, with a unique character for each of them. That¡¯s 27 unique plugins in one! Bypass the EQ or the Compressor and you will hear that the sound variety is almost endless. Variety inspires. VARM II VARM II is technology based on knowledge of chaotic behaviour and randomness of the analogue world. Thanks to VARM II, each plugin instance acts slightly differently. VARM models randomness of the subtle differences of the values of the electrical parts - exactly as in the real electrical units and the real console channels. The result is the truest representation of the hardware units¡¯ sound. 15-Days unlimited trial version for FREE All the descriptions are nothing comparing to putting your hands on the plugin. No saving limits. No noises. No boundaries. Engage the plugin in your project for real and fully exploit its powers for two weeks. Introductory discount 78% 33 instead of 149!!!! just till the November 30th 2021 https://unitedplugins.com/UniChannel/ |
