Zoom R20, new 16-track portable multi-track recorder
2021-11-6 20:34| ·¢²¼Õß: ws6602| ²é¿´: 1389| ÆÀÂÛ: 0
ÕªÒª: Zoom R20, new 16-track portable multi-track recorderSYNTH ANATOMY uses affiliation partner programs (big red buttons) to finance a part of the activity. If you use these, you support the website. Tha ...
SYNTH ANATOMY uses affiliation & partner programs (big red buttons) to finance a part of the activity. If you use these, you support the website. Thanks!
The Zoom R20 is a compact all-in-one multi-track recorder with 16 tracks, integrated stereo effects, and a touchscreen with DAW-style editing.
In recent years, more and more musicians have switched to pure hardware-based setups. Also known as DAWless music production. Computers off and on the hardware Synths, drum machines ¡­ If you want to capture these jams you can often not get around the computer. Because it is fast and cheap. Unless you use dedicated hardware that is capable to record everything.
Many modern, digital mixers have integrated recording functions where you can record the stereo sum or even all tracks individually on an SD card. The disadvantage often, these are often relatively large and cumbersome for quick jams. Zoom today announced the R20, a multi-track recorder that fits in any jam bag. Very exciting for mobile musicians.
Zoom R20
It is not yet official as it is not yet on the official Europe/US Zoom website. But the manufacturer has released details on its Japanese website, the region where Zoom has its headquarters. The Zoom R20 is a new all-in-one digital multi-track recorder with 16 tracks from Zoom in a very compact format. 8 of the 16 tracks can be recorded simultaneously in 44.1kHz and 16/24bit. The device does not seem to be able to record higher, which is a great shame, especially in 2021.
Two of its 8 eight inputs are XLR 1/4¡±, while the other six offers classic XLR connectors. Phantom is also available on the inputs 5-8 so you can also connect microphones to it. In addition to its compactness, it is very hands-on. You get for each input dedicated gain control, record arm button, and level fader. Thus, you have everything under control with your fingers, exactly what you want to see in a hardware-focused system.
Then, you have six transport buttons on the right side including click, rew, ff, stop, play, and record. Very few controls but that is due to the touch display.  The Zoom R20 features a 4.3¡± touchscreen for multi-track editing. The interface is reminiscent of a small portable DAW with your audio tracks display. It offers classic features like split, copy, paste, and more. Of course, you can also move the color-coded regions at the touch of your finger.
Zoom R20
Onboard Effects & More
As in the Zoom L-series, the R20 also comes with onboard studio-quality effects such as a compressor, limiter, 3-band equalizer, noise gate, guitar & bass amp modeling, and a reverb. The limiter gets bonus points, an important feature that the L-series lacks. Very important for jams. Also included are 150 rhythm loops and 18 synth sources, which can be played via MIDI or edited on a piano roll interface on the touch screen.
However, it lacks real MIDI ports, so it will probably work over the USB-C port on the side. The same is also there for using the R20 as an audio interface for your PC/Mac or iOS devices. It operates as an 8 in/4 out audio interface on macOS/Windows while on iOS only with 2 ins/2 outs. Another USB port allows you to connect an optional Bluetooth adapter for establishing a wireless connection to a smartphone and remote-controlling the recorder using the R20 Control app.
Next to the USB ports, you have an SD card slot. The R-20 records onto SDXC cards with a capability of up to 1TB. That should be enough for most jams.
A very exciting device especially for hardware-focused mobile musicians. A downer for me is the 44.1 kHz recording quality limitation. In 2021 I expect higher specs facing the H6 or the H8 ¡°kraken¡±. Both have been offering higher recording rates for a long time. Nonetheless, a neat portable recorder.
Zoom R20 will be available soon. Price TBA.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
