The 2hp Cat Is Back From The Grave, And It Brought A Friend!! The 2hp Cat Is Back From The Grave, And It Brought A Friend!!-catnip_front.jpg Description Introducing the Cat v2, the chilling sequel to our critically acclaimed Cat Synthesis™ VCO. Now featuring an improved synthesis engine running at 96kHz, 24-bit, and with more moods than ever before, you'll think this kitty is sitting on your lap when it purrs. To push the unholy cat synthesis practice further, we have concocted a companion module for our foulest feline: the Catnip. Catnip is a multi-effects module of horror, transforming the cat you once knew into something truly spooky. Strike now before the clock hits midnight on Halloween, when this devilish duo once again return to the grave, possibly forever¡ Cat Synthesis™ VCO Improved synthesis engine running at 96kHz / 24-bit Catnip multi-effects module Voltage controlled cat sounds Hypoallergenic Available direct only, while supplies last! Tech Specs Width: 2HP Depth: 45mm Power Consumption: Cat v2: +12V=85mA, -12V=3mA, +5V=0mA Catnip: +12V=78mA, -12V=9mA, +5V=0mA ________________________________________ MSRP: Cat v2 - 99.00USD Catnip - 99.00USD The Fat Cat Bundle (both modules) - 159.00USD Product Page: https://www.twohp.com/spooktorium/catnip |
