2B Played Music releases Filter Friend creative filter effect plugin 2B Played Music has announced the release of its new audio effect Filter Friend, a plugin designed to provide you with creative and quick filter effects. You can of course use Filter Friend to create great simple creative sweep effects.. But to really let Filter Friend come into its own, you can make use of all the advanced timing-related filter effects, the different filter types, filter strengths, filter waveforms, the distortion options and the built-in eq. Furthermore, you can effortlessly change the strength of any applied filter waveform. You can apply an eq to the filtered result and use our position timing. With the position option, the timing follows the position of your DAW playhead relative to your song length. Filter Friend features 4 Powerful filter types. Mix option. Cutoff control. Resonance control. 5 Different waveforms. Advanced distorion filter. Different filter strengths. Vector based knobs. 20 Tempo modes. Waveform depth knob. Position Sync. Tempo Sync. Free Rate. Factory Presets. Live explanation. Level Control. Filter Friend comes in VST/VST3 and AU plugin formats for Windows and Mac. The plugin is available at 2B Played Music and from ADSR Sounds at an introductory 30% discount until November 19th, 2021. |
