New Audio-Technica Shotgun Mics
2021-10-29 08:11| ·¢²¼Õß: 7906279| ²é¿´: 889| ÆÀÂÛ: 0
ÕªÒª: New Audio-Technica Shotgun MicsBP28 and BP28L line + gradient large diaphragm condensers make their debut New Audio-Technica Shotgun MicsAudio-Technica has launched its new BP28 14-inch (355.6 mm) and ...
Audio-Technica has launched its new BP28 14-inch (355.6 mm) and BP28L 22.4-inch (569 mm) Line + Gradient Large Diaphragm Condenser Microphones. They tell us that these microphones combine a large-diaphragm condenser element with a 28 mm diameter shotgun design for exceptional low-noise performance. A spokesperson said, "With extremely tight polar patterns and a patented acoustic port design that maintains directionality across the entire frequency range, these shotgun microphones are specially designed to meet the needs of broadcast, film, television, outdoor recording and theater applications."
Here's more details in A-T's own words...
Particularly suitable for long-distance miking for audio acquisition for film or professional broadcast, the BP28 and BP28L offer a highly directional pickup pattern, with the BP28L's pattern being exceptionally narrow. They provide a flat frequency response and exceptionally low noise levels (BP28: 8 dB; BP28L: 3 dB) and transformer-coupled outputs that produce a smooth sonic character. Extremely high sensitivity (BP28: -28 dBV; BP28L: -23 dBV), wide dynamic range (135 dB), and high-SPL capability (BP28: 143 dB; BP28L: 138 dB), and they are equipped with a switchable 80 Hz high-pass filter and 10 dB pad. Both. The mics' rugged housing is made of lightweight, structural-grade aluminum alloy.
BP28 and BP28L Line + Gradient Large Diaphragm Condenser Microphone specifications:
Element: Fixed-charge back plate, permanently polarized condenser
Polar Pattern: Line + gradient
Frequency Response: BP28: 20-19,000 Hz; BP28L: 20-20,000 Hz
Low Frequency Roll Off: 80 Hz, 18 dB/octave
Pad: -10 dB
Open Circuit Sensitivity: BP28: -28 dB (39.8 mV) (0 dB=1 V/Pa, 1 kHz); BP28L: -23 dB (70.8 mV) (0 dB=1 V/Pa, 1 kHz)
Impedance: 250 ohms
Maximum Input Sound Level: BP28: 143 dB SPL (1 kHz at 1% THD), 153 dB SPL (When pad is on.); BP28L: 138 dB SPL (1 kHz at 1% THD), 148 dB SPL (When pad is on.)
Noise: BP28: 8 dB SPL (A-weighted); BP28L: 3 dB SPL (A-weighted)
Dynamic Range: 135 dB (1 kHz at Max SPL)
Signal-to-Noise Ratio: BP28: 86 dB (1 kHz at 1 Pa, A-weighted); BP28L: 91 dB (1 kHz at 1 Pa, A-weighted)
Phantom Power Requirements: 11-52 V DC, 3.4 mA
Switches: Low cut: on/off; Pad: on/off
Weight: BP28: 223 g (7.9 oz); BP28L: 313 g (11 oz)
Dimensions: BP28: 354.9 mm (14.0") long, 28.0 mm (1.1") maximum body diameter; BP28L: 567.9 mm (22.4") long, 28.0 mm (1.1") maximum body diameter
Output Connector: Integral 3-pin XLR-M type
Audio-Technica Case Style: BP28: SG6; BP28L: SG7
Included Accessories: Windscreen (BP28: AT8170, BP28L: AT8169), holder (AT8470), stand adapter (3/8"-5/8"), carrying case
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
