BLEASS Intros Dragonfly Tremolo Effect For iOS, Mac & Windows
2021-10-22 09:34| ·¢²¼Õß: 5350210| ²é¿´: 834| ÆÀÂÛ: 0
ÕªÒª: BLEASS Intros Dragonfly Tremolo Effect For iOS, Mac WindowsBLEASS has introduced Dragonfly, described as ¡°a completely new approach to tremolo effect¡±.Dragonfly is designed to let you make your syn ...
Dragonfly is designed to let you make your synths, voices or melody ¡°vibrate¡± in correspondence with its own frequencies. Or ¨C as with sidechain compression ¨C you can have the effect synced to your bass or other track.
Dragonfly automatically syncs the tremolo effect applied on a track using various triggers:
First, you can use the pitch tracking module on either the input audio track (¡°self mode¡±) or a sidechained audio track (¡°sidechain mode¡±).
You also can use the MIDI input to trigger Dragonfly with accuracy: the tremolo will automatically sync with the notes¡¯ frequencies.
Finally, a manual mode allows you to set a fixed frequency. Then you can finetune your settings by adjusting the fine, factor, smoothness, stereo, attack & release.
The ¡°Wild¡± mode applies a waveshaper to the signal to produce a subtle saturation. The final tremolo effect rate is mirrored by the flapping wings of the Dragonfly.
Audio Demo:
Pricing and Availability
Dragonfly is available starting October 20 with intro through November 1, 2021:
Windows & Mac: 15 / $19
iOS: 5,49  / $4,99
Normal price: Windows & Mac: 29 / 35$ , iOS: 9,99 / $8,99.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
