Austen MIDI-Transformer Austen MIDI-TransformerMIDI-Transformer is a useful plug-in that does just what it says: It takes incoming MIDI data and transforms it according to the specified transformation curve and destination. The curve is editable by adding and moving nodes and curve types. This lets you do all sorts of things to incoming MIDI data. For example, you can scale velocity values or change the CC number of controller data. The GUI displays a vertical line for the last captured input value, so it¡¯s also a visual MIDI monitor. MIDI-Transformer is a VST3 plug-in for Windows. |
