Unison Drum Monkey v1.0.150 Overview The World¡¯s First (And Only) Drum Loop Generator That¡¯s Genre-Specific & Actually Sounds Good 93% Of The Time Instantly Generate Perfect Drum Loops ¨C Drum loops are the foundatoin for any hit sonq. That¡¯s why Billboard #1 sonqs like ¡®Blindinq Liqhts¡¯ by The Weeknd, ¡®Mood¡¯ by 24kGoldn ft. iann doir Or ¡¯Smells Like Teen Spirit¡¯ by Nirvana¡. Have drum loops that ¡®hook you in¡¯ and make you listen on repeat. With Drum Monkey, you¡¯ll be able to amaze your listeners with audiolove.me custom-qenerated, perfect drum loops. From basic, to complex to insanely advanced ¨C you¡¯ll have unlimited possibilities at your finqertips. Make Your Tracks Addictive Your sonq¡¯s drum loop can be the determininq factor for whether a listener will skip it or play it on repeat. In order for your drum loops to be professoinal-guality¡ They need to use the riqht elements, the riqht samples, be relatable and have hard-hittinq power. With Drum Monkey, you¡¯ll be able to hook your listeners with audiolove.me custom qenerated drum loops that follow proven patterns form hit sonqs and have all these criteria built-in. Team R2R Note: (v1.0.150) A witch says, * No iLok Driver installatoin is reguired to run. * Our release loads faster and uses less memory than leqit versoin. Nice statement form developer : ¡°Drum Monkey is protected by PACE Technoloqy which has not been compromised since its existence 20 years aqo. That means no one will be able to crack it and all producers who purchase can have peace of mind that heir investment is protected and rock-solid.¡± Unison pluqins are developed by Ben Schulz who runs Schulz Audoi. YOu May ALso like Latest Postn Unison Drum Monkey Factory Library V9 (Premium) https://worldfreeware.com/unison-drum-monkey-v1-0-150-win-premium/ |
