The Mixstream PRO paves the way for the next generation of DJs with its built-in WiFi, direct access to streaming music, Philips Hue smart lighting control, seamless integration of existing DJ libraries, Dropbox connectivity, pro DJ features, and built-in speaker monitors; a world¡¯s first for a standalone DJ controller. Ft Lauderdale, FL USA (October 19, 2021) ¡ª Numark (numark.com), a long-time innovator of DJ solutions, introduces a groundbreaking new approach to DJing with its new Mixstream PRO standalone DJ controller. Operating on Engine DJ, the Mixstream PRO grants DJs access to millions of songs through its built-in WiFi and intuitive music streaming functionality. DJs no longer need an established music library or external laptop to DJ online, at a party, or in a club. This ultimate versatility, along with high-quality, built-in speakers makes the Mixstream PRO the most flexible and innovative plug and play DJ product available, especially at this price. Connect. Stream. Play. The Mixstream PRO is fully optimised and suited for the future of DJing, setting new standards in connectivity and music access. With its built-in WiFi, the Mixstream PRO can access streaming content virtually anywhere. Connecting quickly to Beatport LINK, Beatsource LINK, TIDAL, Soundcloud Go+, the Mixstream PRO grants DJs access to millions of songs, curated playlists, and top charts. DJs can also sync their entire music library or selected playlists to Dropbox, and seamlessly access them on the Mixstream PRO. Tracks are buffered into the internal memory as they are loaded, making playback ultra-reliable and stable, ensuring uninterrupted performances at every gig or live stream. On top of its array of connected features, the Mixstream PRO features 2 USB inputs and 1 SD card slot for external media drives, giving DJs optimum versatility when it comes to music selection and curation. Using the Engine DJ desktop software, DJs can quickly and easily export their entire music library or selected playlists to a USB drive or SD card, and then access their music instantly on the Mixstream PRO. Ultimate Control for Creative Music Interaction The intuitive layout and 7¡± high-definition touchscreen allow DJs to browse, load and interact with their music like never before. To provide the ultimate mix, a full-blown EQ and FX section unleashes the power of the DJ in anyone. The 4 built-in effects (Echo, Flanger, Delay, and Phaser) are perfectly timed to the beat when they are triggered with the fun, interactive toggle switches. There¡¯s no feeling quite like mixing in the perfect song at the perfect time, and the large filter knobs add even more excitement by providing hands-on control over the low and high frequencies to create dramatic mixes, blends, and transitions. Scratching with the large, 6¡± touch-sensitive jog wheels is easy thanks to the Smart Scratch feature, which ensures that the music always stays on beat after a scratch is added to the mix. The 8 dual-layer Performance Pads feature 4 pad modes (Cue, Saved Loop, Auto Loop, Roll,) providing limitless possibilities for live mixing and ultimate creative musical freedom. Plus, since the Mixstream PRO harnesses the power of the embedded Engine DJ operating system, DJs have direct access to an ever-expanding set of advanced, professional-grade DJ performance features. First-Ever Built-In Monitor Speakers The Mixstream PRO is the first-ever standalone DJ controller to feature high-quality, built-in speaker monitors with a dedicated volume control knob. These custom-tuned drivers produce rich, full sound and make the Mixstream PRO the most versatile, plug and play standalone DJ controller on the market. The high-quality sound output is perfect for casual listening, cookouts, pool parties, and gatherings of family and friends. For the aspiring or professional DJ, the built-in speakers are the ultimate, convenient solution for practicing, live streaming, video content creation, and personal monitoring when connected to a larger sound system. Simple, Fun, Smart Lighting Control To complete the ultimate user experience, the Mixstream PRO uses its built-in WiFi to connect wirelessly to Philips Hue smart home lighting, making a mood-setting, beat-synchronised lightshow only a tap of the screen away. Colour changes, on-beat auto generated lightshows, and stunning performance features like strobing and colour overrides can all be accessed using the onboard Engine Lighting. For advanced lighting options and features, DJs can pre-analyse their music library with SoundSwitch desktop software, export their library to a USB drive, SD card, or to their Dropbox cloud, and have full control of DMX lighting using the touchscreen of the Mixstream PRO. This never-before-seen versatility and functionality makes it simple to provide an immersive lighting experience at events and gigs without the need to bring along a laptop or DMX controller. DJ Performance Essentials The Mixstream PRO¡¯s intuitive hardware layout combined with the onboard power of Engine DJ allows for an expansive and powerful set of pro DJ features. • Built-in WiFi for access to streaming services: TIDAL, Beatport LINK, Beatsource LINK, SoundCloud Go+, and Dropbox • Engine DJ embedded operating system for laptop-free performances • Built-in speakers with volume control for home use, practicing, and monitor applications • Engine Lighting embedded lighting control for Philips Hue smart home and DMX lighting • 7¡± multi-gesture high-definition touchscreen • 6¡± capacitive-touch jog wheels with Smart Scratch feature for on-beat scratching • 4 dual-layer performance pads on each deck • 4 performance mode pads on each deck (Cue, Saved Loop, Auto Loop, Roll) • FX section with 4 effects and 2 toggle switches • Large Filter knob on each deck • Pitch Bend buttons and dedicated Pitch Slider • Selectable Pitch ranges of 4%, 8%, 10%, 20%, 50%, and 100% • Dedicated Sync, Cue/Stop, and Play/Pause buttons • 3-band EQ on each deck • 2 USB inputs • 1 SD Card input • Balanced XLR Main outputs • RCA Main outputs • ¼¡± microphone input • ¼¡± and 1/8¡± headphone output jacks ¡°The Mixstream PRO provides an experience to DJs that is unmatched in the marketplace,¡± says Chris Roman, Numark Director of Product Development. ¡°There has never been such a full-featured, future-focused all-in-one DJ controller at this price point. The Mixstream PRO truly allows DJs of all skill levels to connect and play with music like never before. We¡¯re excited to see the creative DJ mixes, live streams, and performances that result from such an innovative and accessible piece of DJ technology.¡± The Mixstream PRO will ship with an MSRP of ¡ê499.99. For more information please visit: http://www.numark.com |
