PreSonus Unveils Updated R-Series V2 Active AMT Monitors
2021-10-21 07:50| ·¢²¼Õß: 59865600| ²é¿´: 860| ÆÀÂÛ: 0
ÕªÒª: PreSonus Unveils Updated R-Series V2 Active AMT MonitorsBaton Rouge, Louisiana¡ªOctober 2021 PreSonus® is now shipping its second-generation R65 V2 and R80 V2 active AMT studio monitors. The new ...
Baton Rouge, Louisiana¡ªOctober 2021 PreSonus® is now shipping its second-generation R65 V2 and R80 V2 active AMT studio monitors. The new monitor speakers feature more extensive control than the original R-series, incorporating the analog Acoustic Tuning controls from PreSonus¡¯ celebrated Eris® line. You get Low Cutoff, Mid Frequency, and High Frequency controls, as well as a three-position Acoustic Space switch that allows you to compensate for the acoustic results of speaker placement against a wall or in a corner. An upgraded 140W (75W LF + 65W HF) Class A/B power amplifier provides ample headroom and even warmer, smoother overall frequency response for distortion-free, non-fatiguing performance, even at higher volumes.
As with the original R-series, the new R65 V2 and R80 V2 monitors feature a custom-designed, 6.8-square-inch Air Motion Transformer (AMT) tweeter that responds to the subtlest waveforms and high frequencies, making them an ideal choice for hearing ultra-highs that add ¡°air¡± and a sense of space and dimension. The AMT¡¯s astonishingly thin (< 0.01 mm) folded Kapton membrane provides wave-cycle-accurate transient reproduction, so you¡¯ll hear every detail in your music: the gentle breath in every exhale, the subtle finger noise in a nylon-string classical guitar, the nuanced overtones of brass and woodwinds; and exquisite reverb tails that gracefully decay.
The AMT tweeter also enables R-series V2 monitors to handle 8 to 13 times the projection area of more traditional tweeter designs, while the monitor¡¯s housing design constrains the projection area to the horizontal axis. The result is a wide ¡°sweet spot¡± with narrow vertical dispersion, minimizing problematic reflections off of your desk, ceiling, and floor, while providing a consistent sound in different listening environments.
The R80 V2 features an eight-inch, custom-woven, composite woofer that offers consistent low-end dispersion across its frequency range. The R65 V2 has a 6.5-inch woofer of the same design. The R80 V2¡¯s overall frequency response is rated at 40 Hz to 22 kHz, while the R65 V2 delivers 45 Hz to 22 kHz.
Balanced XLR and ¼-inch TRS and unbalanced RCA input connections make hookup to almost any line-level source quick and easy. Safety features include RF shielding, current-output limiting, over-temperature protection, and subsonic protection.
PreSonus R65 V2 and R80 V2 studio monitors are available immediately at PreSonus dealers for U.S. street prices of $329.95 and $429.95, respectively. The new R-series V2 monitors replace the original R-series monitors, which have been discontinued. For more information, please visit www.presonus.com/products/Studio-Monitors.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
