Acorn Amplifiers is now taking pre-orders for its new TMA-1 fuzz pedal
2021-10-18 08:22| ·¢²¼Õß: nektan| ²é¿´: 846| ÆÀÂÛ: 0
ÕªÒª: You can now place your pre-order for the new Acorn Amplifiers TMA-1 fuzz pedal. This pedal bears an uncanny resemblance to HAL 9000 from 2001: A Space Odyssey. But rather than turning sentient, it has ...
You can now place your pre-order for the new Acorn Amplifiers TMA-1 fuzz pedal. This pedal bears an uncanny resemblance to HAL 9000 from 2001: A Space Odyssey. But rather than turning sentient, it has lots of sweet fuzz clipping options instead.
ADVERTISEMENT
Acorn Amplifiers TMA-1 Fuzz
The Acorn Amplifiers Fuzz TMA-1 Fuzz features not one, but four stages of transistor fuzz, with a series of selectable diode clipping options. This gives you the choice of flicking between classic germanium and silicon diodes, and makes for a nice flexible fuzz circuit. Each pedal is hand-made in the Acorn Amplifiers Atlanta, GA workshop, using high-quality components. The units are hand-wired, and come with Switchcraft jacks and true-bypass switching. You can power the pedals with a standard 9V negative tip power supply.
Acorn Amps TMA-1 Fuzz
Acorn Amplifiers TMA-1 Fuzz, Hopefully, it won¡¯t open the pod bay doors
HAL 9000
Of course, that big red LED and the silver bezel is what gives this fuzz the space age HAL 9000 look and Acorn Amplifiers have given the pedal a very space-themed design. All the promo material is also very much in keeping with the theme. You may remember the company¡¯s Dune-themed Mind Killer Dual Distortion, so I think the guys that work there may all be sci-fi fans.
Clipping
The pedal has controls for Volume, Tone, and Gain, along with two clipping switches that allow you to combine various combinations of the germanium and silicon diodes. These are labelled Clip 1 and Clip 2, and allow you to choose between Germanium or Silicon, on, or off. Fuzz clipping diodes play a large part in a fuzz pedal¡¯s tone and character, so being able to combine them in multiple ways should be a fun way to experiment with the fuzz tone.
Pre-Order
If you want one, then pre-orders are open now. The first units are expected to ship in December 2021, so not too long to wait for one. You can place your pre-order from the link below. And if you want to hear what this new fuzz sounds like, check out the video demo below.
RRP ¨C Pre-Order USD 199
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
