If you¡¯re making music on a Windows 10 laptop or PC, you need to read this. Not only have we compiled a set of tweaks every musician and producer should know ¨C we¡¯ve even tracked down how to access the power profiles that were removed from Windows 10 in the 2004 Update and 20H2 Version! So if you¡¯ve been experiencing audio glitches on your Windows computer making music, here¡¯s how to get your machine running smoothly. ADVERTISEMENT Updates Windows 10 updates can sometimes bring trauma to us power users. Usually, it¡¯s in areas where we are trying to force our computers into doing something that our non-musical colleagues are not: low latency audio. The majority of computer users are running browsers, email, social media, games, streaming, photo editing and lots of other common tasks and that¡¯s where Microsoft puts their focus. High latency makes all these things run smoothly and that¡¯s a good thing; it gives the computer time to process everything and stream it perfectly to you. But we¡¯re not watching a movie, playing a game or checking our socials: We¡¯re making music, so our needs are different. On Windows desktops there have been no major problems with running low latency, glitch-free audio. The first tweaks in this article are all you need for a smooth-running system for music production. On laptops, hybrids and tablets it¡¯s a different story. Microsoft focuses development for laptops and similar machines on power-saving, adjusting Windows to maximise battery life by minimising CPU usage. This can be problematic for music production because it often results in glitches in audio when playing software instruments and CPU throttling when running projects. Microsoft Strips Registry Tweaks from Windows 10 We¡¯ve been using a registry tweak for quite some time that gives laptop users the ability to access the advanced power settings that Microsoft has removed. This was known as the ¡°Connected Standby¡± or ¡°CSEnabled¡± tweak. Unfortunately, Microsoft stripped this functionality from Windows and the registry in the 2004 and 20H2 update. We lost our ability to access those power settings and run more than a ¡°Balanced¡± power profile. All Microsoft is trying to do is to ensure that their products such as the Surface range can run properly within the limits of their thermal profiles; boosting the power profiles can have a detrimental effect on battery life and the life of the internal components. However, when making music we need to be able to make a couple of tweaks just to get glitch-free playback ¨C without compromising system integrity in any way. Thankfully, I¡¯ve pieced together an answer buried in a few online forums and can show you how to get High Performance on your laptop and regain access to the advanced power options. Disclaimer: All these tweaks are done at your own risk! The Best Windows 10 Tweaks for Audio First, let¡¯s look at some general tweaks that every system needs. This is not as extensive as many other sites and guides suggest because many of the common tweaks have built up over time and are no longer helpful or relevant. Care is needed here: It¡¯s possible to hobble your own system in the pursuit of maximising power. So follow these first, see how that goes, and only if you are still having trouble should you investigate further. If you prefer to see these tweaks demonstrated and want a fully explanation then check out the video at the bottom of this page where I take you through it all. Task Manager ¨C Disabling Start-up entries Right-click the taskbar and select Task Manager If it¡¯s a small window click on ¡°More Details¡± Click on the Start-Up tab. Set everything to disabled. If there are entries that refer to audio interface control panels then leave those enabled. You¡¯ll need to restart for this to become effective. Windows Task Manager Background Apps Right-click the Start button and click Settings. Click on Privacy. Select Speech ¨C turn off online speech recognition. Click on Background Apps ¨C set ¡°Let apps run in the background¡± to off. Windows - Background Apps Anti-virus Some anti-virus software can play havoc with your system when trying to run low latency audio. The inbuilt Windows Security is more than enough for most people and has a very low impact on a system and so is usually fine to leave running in the background. If you want to run more third party security software make sure you can easily disable it IF you find it interferes with your music software or peripherals. If you need to search the dark web while making music then, by all means, leave on lots of internet security ¨C my only point with anti-virus is that it CAN cause issues and IF IT DOES then try turning it off, disabling it or disconnecting yourself from the internet to see if that helps. Power profiles Right-click the Start button, select Settings, click System and select Power & Sleep on the left. Under ¡°Related settings¡± click on Additional Power Settings. If ¡°High Performance¡± is available select it. If not check under ¡°Show additional plans¡± and if it¡¯s not there click on ¡°Create a power plan¡± and see if you can select it in there. If still no luck then you¡¯ll need to skip down to the laptop tweaks below to bring that option back. Assuming you now have a High Performance or Ultimate Performance option select it and click on ¡°Change plan settings¡±. Put the computer to sleep ¨C set to ¡°Never¡±. Click on Change advanced power settings. If there are only a couple of options here then please do the laptop tweak below. Hard disk ¨C turn off hard disk after ¨C set to zero. USB settings ¨C USB selective suspend setting ¨C Disabled. Processor Power Management ¨C set minimum and maximum to 100%. Windows Power Options USB Hub power Right-click the Start button and select ¡°Device Manager¡±. Open up the USB Serial Bus Controllers. Double click any USB hub entries and under Power Management disable the ability to turn off. Windows Device Manager - USB Suspend That¡¯s it for general tweaks. Don¡¯t forget to restart your system and make sure all your drivers are up-to-date. Laptop Power Profile Tweaks This tweak is only required if your system doesn¡¯t have a High-Performance option in the Power Options and there are no Processor Max and Min entries under Advanced Power Settings. These two tweaks are both performed in the Windows Powershell run as Administrator. Right-click the Start button and select ¡°Windows Powershell (Admin). A console-style window will appear where you can enter text and commands. Copy and paste the following into the command line and press enter: powercfg -duplicatescheme e9a42b02-d5df-448d-aa00-03f14749eb61 Then do the same with this line: reg add HKLM\System\CurrentControlSet\Control\Power /v PlatformAoAcOverride /t REG_DWORD /d 0 Windows Powershell After restarting your system go into the power options and you should find an entry for ¡°Ultimate Performance¡±. Select it and finish the tweaks as above. I¡¯d recommend putting your laptop back to ¡°Balanced¡± power when using it for normal things. Turbo Mode On some laptops and systems the Turbo Mode of the CPU causes glitches and instability when running low latency audio. Turbo Mode can be turned off and you may find running your system at the stock CPU speed gives you a glitch-free and more consistently reliable playback. If you are having problems then this is something you should try. Go to the Advanced Power Settings and go down to where you set the Processor Power Management. Set the Minimum and Maximum power to 99% ¨C this disables Turbo Mode. See if that sorts out your problem. Getting deeper For more explanation and advice check out the video I made of applying these tweaks. I hope this was helpful and please let us know in the comments what results you¡¯ve had. |
