United plugins introduce Urban Puncher - a definitive drum improving tool
2021-10-5 12:10| ·¢²¼Õß: 36590990| ²é¿´: 720| ÆÀÂÛ: 0
ÕªÒª: United plugins introduce Urban Puncher - a definitive drum improving toolUrban PuncherUrban Puncher is a definitive drum improving tool for any urban music producer. It doesn't matter much if you can ...
Urban Puncher
Urban Puncher is a definitive drum improving tool for any urban music producer. It doesn't matter much if you can put it on your drum channel after or before your EQ or comp. Simply dial how strong the punch your tracks get should be and mix it with the original sound and let Urban Puncher do its magic.
Punch
What is a "Punch"? There's not a simple answer to that. The punch knob controls several processes at the same time. It can be described as an esoteric dynamic process with transients treatment and spectral shaping.
Saturate
Analogue-like transformer/tube blended emulation of saturation gives the punch a completely different feel. Use it gently to make your track blend in easily or dial the Saturation knob all the way up to get the real street sounds.
Destroy
And you can even punish your drum loops with the Destroy button. Hitting that triples the values you dial with the saturation knob. That results in a heavier form of distortion.
Experiment
Although the primary UrbanPuncher intention is for drum loops it is not where you should stop. The plugin can give extra punch to other instruments such as acoustic guitar or piano. Don't be afraid to experiment.
Hassle-free software protection
No iLok, no dongle nor internet access is required for activation. Our software uses license files to activate your software. You can freely use the purchased software on all your computers as long as you are the user
UrbanPuncher compatible with the majority of VST/AAX/AU DAW applications on both Windows and macOS.
The price is set to
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
