ÒôƵӦÓà › Ê×Ò³ ›Ó²¼þ³§¼Ò › ²é¿´ÄÚÈÝ
ÒôƵӦÓÃÉ̼ÒÈëפ
ANWIDA Soft releases PEQ1V Parametric EQ Plug-in with intro offer
2021-10-3 09:51| ·¢²¼Õß: stillson| ²é¿´: 1018| ÆÀÂÛ: 0
ÕªÒª: ANWIDA Soft has announced the release of PEQ1V, an "old school" parametric equalizer plug-in based on an easy-to-use interface that drives a powerful constant Q minimum phase equalization algorithm.AN ...
ANWIDA Soft says:
The PEQ1V parametric equalizer is the tool of choice to control the equalizations of vocal parts, instruments or complex mixes.
PEQ1V provides an extremely transparent action with a natural and smooth response.
PEQ1V is a VST3/AU plugin and comes with a signed installer for Windows and signed/notarized installer for OS X/macOS. It loads natively in macOS Big Sur running on Apple Silicon.
Intro Price: $25 (50% off; Reg. $49) until October 10th, 2021 11.59 PM CET.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵӦÓý»Á÷Íø
ÒôƵ±à¼­Èí¼þ
