JP Cimalando DelayArchitect JP Cimalando DelayArchitectThe Delay Designer has long been one of the best plug-ins in Apple¡¯s Logic Pro. DelayArchitect is a free, open-source adaptation of the concept. Like Delay Designer, DelayArchitect is the ultimate delay tool box: You can create custom delay effects by creating as many taps as you¡¯d like and dialing in the volume, cutoff, resonance, tune and panorama for each one of them independently. It syncs to your song tempo and even swings. If you¡¯re not a Logic user, this one is a must-have. DelayArchitect is available for Windows, macOS and Linux in VST3 and AU formats. |
