Recluse-Audio 808-ROMpler
2021-10-1 07:02| ·¢²¼Õß: 7598170| ²é¿´: 1003| ÆÀÂÛ: 0
ÕªÒª: Recluse-Audio 808-ROMplerRecluse-Audio 808-ROMplerAdding classic, boomy 808-style bass drums to your tracks doesn¡¯t get any easier than this. 808-ROMpler is a simple sample player that comes with 16 ...
Recluse-Audio 808-ROMplerAdding classic, boomy 808-style bass drums to your tracks doesn¡¯t get any easier than this. 808-ROMpler is a simple sample player that comes with 16 samples. While they¡¯re definitely in the style of the legendary 808, the developer says that they were actually recorded on a DSI Tempest. You can edit each sound using the included ADSR envelope. And if you prefer to use your own samples, you can simple drag&drop them onto the interface ¨C so it¡¯s actually not a ROMpler at all.
808-ROMpler is available for macOS and Windows in VST3 and AU formats.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
