Cybergrunge FSUMpeg Cybergrunge FSUMpegThis is a digital lo-fi plug-in, but the developer is quick to point out that it¡¯s not another bit crusher. Instead, FSUMpeg emulates the sound of highly compressed, low-quality audio filters formats like low-res MP3s, cellphone voicemail compression and early 90s voice recorders. They even threw in two ring modulators to make it sound ¡°extra sh*tty¡±. If you¡¯ve ever wished for a plug-in that helps you to relive the years you spent downloading MP3s from Napster, this is the one. FSUMpeg is a VST plug-in for Windows. |
