Soundiron releases Hyperion Brass Elements for Kontakt Player
2021-9-26 09:26| ·¢²¼Õß: toncc7| ²é¿´: 655| ÆÀÂÛ: 0
ÕªÒª: Soundiron has announced the release of Hyperion Brass Elements, the next chapter in their orchestral line of products. It's built for the free Kontakt 6 Player and NKS hardware.Soundiron Says...Hyperi ...
Soundiron Says...
Hyperion Brass Elements is a deeply sampled chamber brass ensemble library recorded at the historic Studio A at Fantasy Studios in Berkeley, CA. Featuring an intuitive modular design, robust articulation list and instrument sections including: Trumpets, Horns, Tenor Trombones, Bass Trombones, Euphoniums, and Tubas. Recorded with an uncompromising quality, this is everything you need to start composing for orchestral brass arrangements.
Hyperion Brass Elements includes 10 combo ensemble presets and 6 Master and True-Legato section presets for 6 Trumpets, 4 Tenor Trombones, 4 French Horns, 3 Euphoniums, 3 Bass Trombones, and 3 Tubas. The Master presets include a broad selection of fundamental articulations, each with their own range of customizable real-time performance options, key-switch and mapping options and performance tools. These master presets allow you to blend and switch effortlessly between vibrato and non-vibrato sustains, a variety of shorts and naturally dynamic tempo-based expressions.
Intro Price: $79 until September 28th, 2021, at soundiron.com (reg. $99).
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
