Overloud ¨C GEMS BUNDLE 2021.5 (STANDALONE, VST, VST3, AAX, AU) [WIN.OSX x86 x64] Year / Date of Issue: 05.2021 Version: 2021.5 Developer: Overloud Developer site: Overloud Format: STANDALONE, VST, VST3, AAX, AU Bit depth: 32bit, 64bit Tabletka: present \ R2R System requirements: VST, VST3, AAX, AU host Description: OVERLOUD GEMS is a set of high quality mixing and mastering plugins. We¡¯ve put the best DSP algorithms and hardware emulation techniques available in every GEM and enriched these products with additional parameters and features, sequential preset control, A / B comparison, and undo / redo support. Content : Overloud.Gem.Comp-G.1.0.2 Overloud.Gem.Comp.LA.1.0.2 Overloud.Gem.Comp76.v2.0.6 Overloud.Gem.Comp670.1.1.3 Overloud.Gem.Dopamine.1.1.6 Overloud.Gem.ECHOSON.1.0.4 Overloud.Gem.EQ84.1.3.2 Overloud.Gem.EQ495.1.2.2 Overloud.Gem.EQ550.1.1.2 Overloud Gem OTD-2 v1.0.2 Overloud.Gem.Sculptube.1.0.2 Overloud.Gem.TAPEDESK.1.2.2 Activation on macOS with pictures : 0. Remove the previous version. 1. Install. 2.Using the command in the terminal sudo nano / private / etc / hosts, run the hosts file and manually add entries 127.0.0.1 www.overloud.com 127.0.0.1 www.overloud.net 0.0.0.0 www.overloud.com 0.0.0.0 www.overloud.net And save (see pic) 3. Go to system settings Network> Advanced> Hardware tab Launch keygen, select a product and enter the mac-address in the corresponding field without colons ¨C just in numbers and letters: And click on the Gen (Mac) button. In this case, a license file OL76.ol2 will appear on the desktop (depending on the program that launches kijen) Run the plugin (or STANDALONE version) and close, ignoring the activation window: After opening and closing the plugin, a folder will be created in the place we need. 4. Copy the license file OL76.ol2 and paste it into a folder along the path Users ▸ admin (USER NAME) ▸ Libraries ▸ Application Support ▸ Overloud ▸ TH-U Please note that this path is not a system path, but a user path, and the Libraries folder is hidden by default (see Internet). 5. Run the plugin. Done |
