Ricardo Plugins Off-Grid Ricardo Plugins Off-GridOff-Grid by Ricardo Plugins is a colorful and experimental drum machine that will keep you inspired for days. It has seven channels with four voices or cells each. Each cell has independent volume and pan controls and can hold one of the 448 included sounds, which can be pitched, reversed and looped. But the real fun starts when you roll the dice and use the plug-in¡¯s many randomization features, which will help you to come up with something new in no time. Off-Grid is a VST and VST3 plug-in for Windows (64 bit). |
