Superbooth 2021: Malevolent ¨C an evil little patchable monosynth
2021-9-22 14:26| ·¢²¼Õß: 5213320| ²é¿´: 643| ÆÀÂÛ: 0
ÕªÒª: Malevolent is a devilishly compact analogue semi-modular monosynth with independently patchable oscillators and endlessly evil intentions.ADVERTISEMENTMalevolentBuilt by PWM, the design comes from Bri ...
ADVERTISEMENT
Malevolent
Built by PWM, the design comes from Bristol-based Future Sound Systems and was developed by ex ROLI and Focusrite engineer Ben Supper along with PWM owner Paul Whittington. It¡¯s in this meeting of experience and intent that we get this intriguing analogue modular synthesizer that¡¯s both instantly playable and endlessly patchable. It also has one of the most convincing sound demo videos I¡¯ve seen in ages:
So, what¡¯s the deal? You have 2 VCO with saw, triangle and pulse outputs and a mix output, shape control, 2 FM inputs and individual mixing. There¡¯s a 2-pole multimode VCF with modulation inputs, there are two envelopes and an LFO. It¡¯s all normalled for instant sounds but there are 19 inputs and 19 outputs for patching making it extremely adaptable.
For control, you have 32 velocity-sensitive mini-keys which are totally independent of the analogue circuit and use USB-MIDI to 1volt/oct conversion to address the synthesizer. An arpeggiator comes with 6 types, latch and up to 6 octaves. The joystick offers a bit of pitch bend, portamento and vibrato.
On the back, Melovolent has a line output and a headphone output, is powered over USB and also has MIDI.
It sounds really fruity and those 2 oscillators give an uncommon amount of girth in a little synth. It¡¯s priced at ¡ê499.99 and they are open for preorders. PWM will be in booth W365 at Superbooth.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
