Instruments Of Things Intros SOMI-1 Gestural Music Controller
2021-9-22 12:13| ·¢²¼Õß: 5213320| ²é¿´: 922| ÆÀÂÛ: 0
ÕªÒª: Instruments Of Things Intros SOMI-1 Gestural Music ControllerInstruments Of Things has launched a Kickstarter project to fund production of SOMI-1, a wireless gestural sensor system for translating mo ...
Instruments Of Things has launched a Kickstarter project to fund production of SOMI-1, a wireless gestural sensor system for translating movement into sound.
The Bluetooth sensors are designed to be be worn on the wrists and ankles, ¡°turning the user into an instrument.¡±
Each SOMI-1 sensor provides eight different motion parameters that can be used independently to control or trigger sound. The sound can either be generated via the SOMI-1 smartphone app, which offers several different sound presets, or by any instrument or music software that is compatible with MIDI.
The motion data of the SOMI-1 sensors is received wirelessly via Bluetooth 5 by the SOMI-1 hub, that connects to your sound source via USB or TRS-MIDI. Up to six sensors can be used simultaneously with a single SOMI-1 hub.
Features:
8 different movement parameters per sensor
Easy usage, no need of musical or technical pre-knowledge
Smartphone app as sound source
Connectivity to music software & hardware as sound source
Hub with MIDI interface (USB & TRS)
Wireless via Bluetooth 5
Up to 6 sensors simultaneously
Pricing and Availability
A SOMI-1 system, with SOMI-1 Receiver & 2¡Á SOMI-1 Motion Sensors is available to project backers for about $444.
Note: Crowdfunded projects involve risk. See the project site for details.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
