BBE Sound "Stomp Board" Now Available BBE and Plugivery Development are today proud to announce the release of BBE Sound¡¯s ¡°Stomp Board¡±. In partnership with BBE Sound, Plugivery development has created Stomp Board; a standalone host application/plug-in including a guitar preamp section and 8 guitar effect pedals taken from the original BBE Stomp Ware classics. Stomp Board is available now in AAX, AU, VST and VST3 format for Windows and macOS from worldwide dealers. The BBE Sound Stomp Board Stomp Board is a standalone application and plug-in set containing the host "Stomp Board" with an integrated Amp Simulator, and 8 premium modeled effect plug-ins (pedals) from the original BBE Stomp Ware classics. Each pedal is available separately outside of the Stomp Board host and is backward compatible with the former Stomp Ware product line for DAW sessions (except RTAS format, now depreciated). Stomp Board supports unlimited loading of the 8 selective pedals highlighted below, each of which can be chained in any order via simple drag/drop operation in the GUI. It includes a dedicated and finely tuned Gate for guitarists, 4 integrated Amp models from clean to light crunch, a tilt style Tone control for global EQ settings and inbuilt spring reverb alongside input/output control and gain staging metering view, and a selection of crafted presets by industry staff musicians. BBE Stomp Pedals Free Fuzz The Free Fuzz was patterned after a rare and sought-after silicon transistor fuzz pedal made famous by players like Jimi Hendrix in the late ¡®60s. It provides a wide range of creamy, dynamic fuzz effects with an almost endless amount of sustain for soloing and chunky rhythms. Green Screamer The Green Screamer is a vintage overdrive capable of producing a dynamic range of smooth and warm overdrive tones associated with vintage tube amplifiers. Mind Bender The Mind Bender is a dual-mode vibrato/chorus that utilizes a BBD (Bucket Brigade Delay) circuit that produces a wide range of warm, lush vibrato, chorus, and rotating speaker effects. Opto Stomp The Opto Stomp is a transparent optical compressor that provides a wide range of soft-knee compression effects, reminiscent of the best vintage compressors made in the ʻ60s. Sonic Stomp The Sonic Stomp is a stomp-box version of the ever-popular Sonic Maximizer. The Sonic Stomp was carefully designed to deliver the same sonic improvement as the rack-mounted 482i Sonic Maximizer, adding clarity, definition and punch to any instrument. Soul Vibe The Soul Vibe is a vintage vibe/rotary speaker simulator known for its chewy phase-like textures made popular in the late ʻ60s and ʻ70s by such players as Jimi Hendrix, David Gilmour, and Robin Trower. Tremor The Tremor is a dual-mode Tremolo/Auto-Pan that utilizes an optical circuit to create a wide range of warm pulsating sounds normally associated with the "vibrato" effect of vintage tube amps. The Tremor ʻPlug-Inʼ offers the flexibility of two independent effects that are foot switchable (to keep the original hardware look), enabling a player to select between a Tremolo effect and Auto-Pan effect. Two Timer The Two Timer was inspired by the long discontinued DM-2 Delay, which was known for its warm, haunting reverb and tape-like echoes. The Two Timer offers two independent delay times foot switchable via the Time1/Time2 mode footswitch. In the software version, we changed the Time1/Time2 switch label to MONO (Time1 delay) and STEREO (Time1: left delay time, Time2: right delay time), it results in having a mono and stereo vintage delay that can create an amazing range of space effects. Pricing & Availability LIST: $129 MAP: $99 Introductory Promo (ending Aug. 31, 2018): $29 BBE Sound Stomp Board is available now from all global and reputable pro audio resellers and music stores listed at Plugivery: Dealers List - Plugivery |
