Universal Audio announces Luna 1.2 with Sidechain Input
2021-9-18 08:57| ·¢²¼Õß: 3263790| ²é¿´: 845| ÆÀÂÛ: 0
ÕªÒª: Universal Audio announces Luna 1.2 with Sidechain Input and MCU Control Surface SupportThanks to feedback from the entire LUNA community, we¡¯re proud to introduce LUNA v1.2. This major software updat ...
Thanks to feedback from the entire LUNA community, we¡¯re proud to introduce LUNA v1.2. This major software update includes over 20 added features and enhancements since the last major release.
New features:
Sidechain Input
New Sidechain utility feature allows assignment of a persistent sidechain input per track/bus
Sidechain directly from Console emulations (API Vision Channel Strip / API 2500) or any capable Audio Units plug-in
Sidechain trim allows you to adjust the sidechain source track level
Sidechain Solo allows you to temporarily listen to the sidechain source
Control LUNA using any control surface that implements the Mackie Control Universal protocol
Configure up to 6 MCU compatible control surfaces on the new CONTROLLERS tab of the SETTINGS page
Dedicate a single fader controller as a "Focus Module" that always follows the LUNA Focus Channel based on track selection
Use your surface to change volume and pan, toggle mute, solo, and record enable for every track in your session
Spill Bus track sources onto the surface using the record enable button
Change automation modes for selected tracks so fader moves can easily be recorded during playback
Control LUNA's transport controls and toggle looping and click
Access many additional controls using common surface features like zooming, scrolling, and much more
Learn more: https://help.uaudio.com/hc/en-us/articles/4406796987540
Improved
LUNA v1.2 will automatically install iLok License Manager 5.4
Copy to CUES and Copy to SENDS command now works based on the track selection instead of all tracks
Using keyboard shortcuts to extend the track selection now scrolls the timeline view when necessary
Focus Channel now shows the last selected track in a selection of tracks and switches to any clicked track in an edit group where all tracks are selected
Download now: https://www.uaudio.com/uad/downloads/
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
