Moog pumps up the Moog Sound Studio to 3-tiers
2021-9-16 13:25| ·¢²¼Õß: 83266790| ²é¿´: 884| ÆÀÂÛ: 0
ÕªÒª: Superbooth 2021: Moog pumps up the Moog Sound Studio to 3-tiersWe knew it was coming, the 3-tier version of the Moog Sound Studio which features the Mother-32, DFAM and Subharmonicon in one awesome pa ...
We knew it was coming, the 3-tier version of the Moog Sound Studio which features the Mother-32, DFAM and Subharmonicon in one awesome package.
ADVERTISEMENT
Moog Sound Studio
When Moog released the first two Moog Sound Studios back in March we immediately asked why they didn¡¯t do a 3-tier version that had all three of the Moog 60HP semi-modular synths in it? The little mixer and power unit that came with the 2-tier version (Mother-32 & DFAM or DFAM & Subharmonicon) even had room for a third unit and a 3-tier bracket already existed. Well, here we have the new expanded 3-tier Moog Sound Studio that does exactly that and it¡¯s completely beautiful.
In true Moog style the new Moog Sound Studio is a wonderful thing to behold. It¡¯s classic, classy and deep in both aesthetic and functionality. The Mother-32 is the benchmark of semi-modular monosynths, the DFAM is an adventure in percussive sounds and the Subharmonicon is an experiment in weirdness. The combination brings together some fabulous scope for music-making and sound exploration.
Moog Sound Studio
But it¡¯s not just a box with 3 products inside, the Moog Sound Studio has been thoroughly thought out and executed with an awesome amount of style and creativity ¨C it makes you want to inhabit the world of Moog. In the box, you get a unique little mixer and power distributor that means you only need one power plug for the whole stack and you can mix the outputs together to a single output. You get a bunch of branded patch cables with a cable rack that fits onto the back of the setup. There¡¯s also a synth exploration card game, creative learning tools, a patch manual, artwork and all sorts of bits and pieces. Moog has added a dust cover that the other 2-tier systems didn¡¯t get which is a very useful addition.
Moog Sound Studio
I did a review of the Mother-32 & DFAM version and all the extras do make a worthwhile difference particularly if you are less than a complete synth head.
Moog will be demonstrating this new Sound Studio at Superbooth in booth Z120 and while it contains no new synths I think it¡¯s a brilliant package that could turn your life around, inspire creativity and make you more appealing to your desired sexual companion. You¡¯re probably going to have to change all your furniture to match.
The new bundle costs around the $2,000 mark and is available now at retailers like Thomann (affiliate link).
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
