Superbooth 2021: Fred¡¯s Lab ZeKit 4-voice paraphonic synth kit
2021-9-14 08:48| ·¢²¼Õß: 57388390| ²é¿´: 873| ÆÀÂÛ: 0
ÕªÒª: ZeKitThis is the first synth to emerge from Fred¡¯s Lab since the dashing TÖÖRÖ appeared last year. This one is a bit simpler, smaller but still full of character.It has 4 voices of pol ...
ZeKit
It has 4 voices of polyphony running digital waveforms through a single VCA and analogue filter. It uses Additive Sawtooth synthesis with 8 mono and 8 para waveforms. There are two ADR envelopes with their knobs front and centre and you also get a filter cutoff knob and Accent. The Accent will have something to do with the internal 96-step sequencer. The filter section has an option for low or bandpass filtering and an intriguing switch where you can choose ¡°Chill¡± or ¡°Acid¡± for the filter resonance response. Another switch brings in external audio to mix into the filter.
View this post on Instagram
Build it yourself
ZeKit will be available as a kit ¨C hence the name ¨C and will be priced very affordably. Fr¨¦d¨¦ric hopes the accessibility of the kit will give beginners something to get their teeth into. It comes with a 30-page assembly guide and detailed explanations of how everything works. All the designs are provided under Creative Commons and Open Source licenses.
The pricing for the kit is
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
