FL Studio 20.8.4 includes native Apple Silicon support, Frequency Shifter & more Image-Line has announced an update to the FL Studio music production software for Windows and Mac. Version 20.8.4 brings native support for Apple Silicon, a brand new Frequency Shifter effect, Video Scrubbing in the Visualizer, improvements to the 3x OSC synthesizer, and much more. We¡¯re always adding more so you can do more with your favorite DAW application. All because we love YOUR Lifetime Free Updates! Changes in FL Studio 20.8.4 Apple Silicon Support: Native ARM code support for Apple Silicon (M1 and related CPUs). 3x Osc: Added anti-aliasing to oscillators. Frequency Shifter: Special effect to create metallic, dissonant, ring modulation and phasing effects. Included with Producer Edition and up. Control Surface: Added a ¡®Show labels¡¯ option to show or hide control labels. Toolbar: Added a toolbar button to change set language. This will appear by default when the language is changed from the default. Edison: Apply visualization options without closing the menu when (Right+Click) is used. Renamed ¡®Disable undo for large samples¡¯ menu to ¡®Enable undo for large samples¡¯. Piano roll: Added an option to preview notes as they are mouse clicked into the piano roll during playback. Maximus & Limiter: Added a menu option to disable the -0.2 dB safety margin. Mixer Menu > Recording: Added an option ¡®Apply track level and mute when recording¡¯ so these can be ignored when recording ¡®Post¡¯ effects in the mixer MIDI Settings: Added ¡®Pickup¡¯ functionality for controls linked to external controllers (option in General settings) ZGameEditor Visualizer: Web cams can now be used in multiple instances of the plugin at once. There is also a new ¡®Luminance average¡¯ internal controller for each buffer available on the (Right+Click) Link to controller option. New video scrubbing option using the ¡®Video Controller effect. New ¡®Peakmap¡¯ effect by Dubswitcher. Playlist: Renamed ¡®Consolidate track(s) > Full song¡¯ to ¡®From song start¡¯ to match export options. MIDI Scripting: Added: Option to get user defined name to the GetPluginName function. function mixer.isTrackMuteLock, getTrackStereoSep and setTrackStereoSep functions to mixer module, function to get color of keys for a specific plugin (only FPC for now), Hardware_Refresh_ControlValues flag for OnRefresh event. Patcher: Added (Ctrl+C) and (Ctrl+V) for copy and paste on inactive parameter popups Mixer: Increased brightness of volume (dB) label on Mixer Tracks Mixer: Track (Right-Click) & Mixer Menu options to reset routing for selected Mixer track(s) to default. Automation: Added a Mode option to the Global Link popup. File Menu: Added options Export all playlist tracks > ¡®From track start¡¯, ¡®Song start¡¯ or ¡®Time selection¡¯. FL Studio Mobile: Updated. See here for changelog. Piano roll > Note properties: The Note Properties dialog is now always shown on the same screen as the Piano roll. Windows File Browser: Replaced all folder selection windows with the modern OS File Browser window. Burn to MIDI: Additional reset options for Swing and Arpeggiator pop-up after selecting Burning MIDI. FL Studio 20.8.4 is available as a free update to existing FL Studio users, and new users can download a free, fully functional time unlimited trial version. |
