SNFK Music releases GlowComp free compressor effect plugin SNFK Music has announced the release of GlowComp, a versatile stereo bus compressor plugin designed for processing a large variety of instruments. It is very gentle on dynamics and helps glue multiple instruments together. GlowComp features Input / Output parameters: Push the compressor by making the input louder (which will also generate extra harmonics). 5 built-in ratios: Changing the ratio knob will affect more than just the ratio as it changes many other internal parameters designed to add some extra character. Timing: Plain and simple attack and release to control how the compressor reacts to the input. LCD screen: Shows input, output, and compression values. CPU Friendly: GlowComp¡¯s algorithm is designed for low CPU while still delivering an impressive sound. The plugin is free to download for Windows and Mac in VST3 and AU formats. |
