Faselunare! Modular Synthesizers & Electronic Musical Instruments
2021-9-6 23:00| ·¢²¼Õß: andreas| ²é¿´: 924| ÆÀÂÛ: 0
ÕªÒª: Faselunare! Modular Synthesizers amp; Electronic Musical InstrumentsVEGA is the first module of the italian company Faselunare. Is a 6HP, 4 Voices drum module in Eurorack format.VEGA has 4 digital voi ...
VEGA has 4 digital voices tailored for drum sounds, each voice works both in synthesis and with samples uploaded on the  onboard SD card.
His unique color coded user interface, shrink the module at only 6HP, thanks to the RGB encoders, LEDs and buttons, you can access easily 12 parameters per voice, 5 presets and a very useful mute function for each voice.
VEGA has 4 Trigger inputs (one for each voice), 1 Random input which randomly triggers individual voices and a high quality audio output.
Why VEGA?
Here at FASELUNARE (Moon-phase in English), we have a passion for space and sci-fi, Francesco's Stage name has always been Urbanspaceman and together with Daniele he played and released some records as the "Space Aliens From Outer Space".
So that's why our projects have names inspired by science and science fiction!
If you look at an image of the Lyra constellation, you will notice that the 4 buttons of our module are positioned exactly like the 4 stars: Vega (¦Á Lyrae, the brightest), ¦Ã Lyrae, ¦Â Lyrae and ¦Ä Lyrae.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
