New Korg Volca Sample Editor Developer Momo M¨¹ller has introduced a third-party MIDI Editor and Controller for the Korg Volca Sample. With the Volca Sample Editor, you have direct access to all parameters and can save them as a Preset Data File and load them back into the Volca Sample at any time. With the plugin version, you can also record controller movements into your DAW. Features: The Editor is a simple integration of the Volca sample into your DAW. Quick and easy sound changes of all parts. Direct access to the sound parameters All controllers can be automated. X-Y Modulation of all parameters is possible. With the „Random¡° function new sounds can be generated quickly for each Sample Part. A sound management. Part Presets can be saved. (E.g. TR 909 Bass Drum) Which you can load into any Part (1-10). Part Kit can be saved.(E.g. TR 909 Kit) Hidden controller ¡± Sample Start Delay¡± for Volca Sampler 2 is included. Contains 50 Presets. Works with Volca Sample Version 1 and 2. Pricing and Availability The Volca Sample Editor is available now for PC and MAC-M1 for 6,90 / $ 7,90. |
