The King 2 multiband compressor by W.A. Production on sale at 92% OFF
2021-9-2 23:04| ·¢²¼Õß: bluem| ²é¿´: 724| ÆÀÂÛ: 0
ÕªÒª: The King 2 multiband compressor by W.A. Production on sale at 92% OFFPlugin Boutique has launched a sale on The King 2, offering over 90% off on the multi-band compressor effect by W.A. Production for ...
Plugin Boutique has launched a sale on The King 2, offering over 90% off on the multi-band compressor effect by W.A. Production for a limited time.
¡°The King 2¡± is a Dynamically Enhanced Multi-Band Compression Plugin designed for Mastering.
It will quickly allow you to dial in an amazingly clear and professional sound that is perfect for EDM, Drum & Bass, Trance Music and much more!
The King 2 features
5 Band Compressor ¨C Low, Low Mid, Mid, Mid High, High
The Mix Knob ¨C toggle between hearing how much of the effect is being used and compare it to the dry mix. You can also use the Mix Knob as a parallel compressor.
Built-in Limiter ¨C keeps the master track, individual audio file or MIDI instrument from exceeding the 0dB mark.
Upward & Downward Compression ¨C These effects are two separate knobs, adjusting either will increase or decrease the compression type.
Time Knob ¨C adjust the attack and release time of the Upward and Downward Compression.
Magic EQ ¨C add EQ to anything being affected whether it be a master rack, individual audio file and or MIDI instrument. The Magic EQ has 3 different shapes/curves that are designed mainly for cleaning.
The King 2 is on sale for $7.90 USD September 30th, 21 (regular $99 USD). The plugin supports VST/VST3, AU and AAX formats for Windows and Mac.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
