Code Sounds releases Abstract Beats sample pack by Sonny Nieuwenhuizen Code Sounds has announced the release of a new sample pack produced by electronic music producer and sound designer Sonny Nieuwenhuizen. Following his debut sample pack Cinematic Ambience, this time Sonny dives deeper into the abstract and experimental depths of sound design with Abstract Beats. The sample pack explores the darker elements of IDM, Cinematic, Glitch and is an essential tool for film projects, game designers and music producers in search of a distinct and massive collection of abstract beats and textures. This sample library includes 60 Full Abstract Beat Loops with 387 Total Drum Loop Stems, and in these stems are where the real inspiration shines, either by using the polished and expertly processed Kit Loops for instant song creation or you can go deeper and mix and match the hundreds of loops including Glitch, Perc, Textures, Deep Kicks, Chopped Snares, Crisp HiHats and much more! Also included in Abstract Beats is a go to collection of 266 cutting edge Drum Hits and 64 Oneshots so you can quickly program your own patterns. When you hear a Beat or Drum Loop containing a sample you want to roll with, you can easily find many of the samples available as Oneshots and Drum Hits labelled with matching Kit info for your convenience. The sample pack is available from Loopmasters, priced ¡ê19.99 GBP / $24.99 USD. |
