BPB Saturator Is A FREE Tube/Tape Saturation VST Plugin
2021-8-26 16:58| ·¢²¼Õß: d-Box| ²é¿´: 1226| ÆÀÂÛ: 0
ÕªÒª: Bedroom Producers Blog releases BPB Saturator, a freeware tube and tape saturation effect in VST, VST3, AU, and AAX plugin formats for digital audio workstations on Windows 10 and macOS.BPB Saturator ...
BPB Saturator is a freeware waveshaping saturation plugin. It is our holiday gift to you. Thanks for reading Bedroom Producers Blog! ❤
The plugin emulates tube-style distortion and tape-style saturation. It is optimized to sound great, albeit with low CPU consumption.
We wanted to create a saturation tool that is lightweight and easy to use. Emulate a tube preamp by applying a bit of tube saturation, then simulate passing your audio through a tape machine with a bit of tape saturation. Or, go crazy and boost the input to use BPB saturator as a dual distortion effect.
BPB Saturator also features a pair of filters (high-pass and low-pas) that are smooth and transparent. Use the filters to clean up the signal, or to isolate a section of the signal that needs to be distorted. For example, try removing the top end from a bass sound, then add plenty of tube drive for a more aggressive sound.
How To Use BPB Saturator?
BPB Saturator is the more nuanced follow-up to our BPB Dirty Filter plugin. Whereas BPB Dirty Filter excels at over-the-top distorted sounds with plenty of filter resonance, BPB Saturator can deliver a far more subtle form of saturation.
You can use BPB Saturator to warm up virtual instruments, drum loops, bass sounds, or even the entire mix. Experiment with applying a subtle amount of tube saturation first to drive the signal. Then, add some tape saturation to introduce odd harmonics and level out any excess volume peaks.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
