UnplugRed Plastic Funeral
2021-8-25 08:32| ·¢²¼Õß: X25123| ²é¿´: 661| ÆÀÂÛ: 0
ÕªÒª: UnplugRed Plastic FuneralUnplugRed Plastic FuneralYou may have guessed that Plastic Funeral by UnplugRed is all about destruction. It¡¯s a harsh and metallic distortion with an FM vibe that ¡°sounds l ...
UnplugRed Plastic FuneralYou may have guessed that Plastic Funeral by UnplugRed is all about destruction. It¡¯s a harsh and metallic distortion with an FM vibe that ¡°sounds like a laser beam¡±, the developer says. You can adjust the frequency, drive, fatness and stereo width. There¡¯s also a knob to blend the dry and compressed signals, as well as an overall output gain control. If you¡¯re bored by ¡°warm¡± distortion effects and ready for something harsh and metallic, give Plastic Funeral a try.
Plastic Funeral is available for Windows and Linux as a VST plug-in.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
