New plug-in brings the Harrison 32C console sound into any DAW
2021-8-22 12:44| ·¢²¼Õß: 6405260| ²é¿´: 1001| ÆÀÂÛ: 0
ÕªÒª: Harrison Consoles Announce 32C ChannelNew plug-in brings the Harrison 32C console sound into any DAW Harrison Consoles and Distribution partner Plugivery have announced the availability of the 32C Ch ...
Harrison Consoles and Distribution partner Plugivery have announced the availability of the 32C Channel plug-in, now available through pro audio resellers worldwide in AAX / AU / VST / VST3 formats, for Windows and macOS. This is what they have to say about it...
For more than 45 years Harrison analog consoles have been a mainstay in studios around the world. The Harrison 32 Series was used on countless renowned albums, generating the sounds that we all carry in our hearts today.
The 32C Channel Plug-in is the latest high-end product from Harrison based on the original Harrison 32C analog console from 1975.
Like the EQ in Harrison's acclaimed Mixbus32c workstation introduced in 2016, the 32C Channel Plug-in uses a complex emulation of the original Harrison 32C EQ. Every resistor, capacitor, and transistor is included in the model. Now you can give your mix the classic Harrison 32C sound you've been looking for, regardless of which host you use.
The 32C Channel Plug-in is a fully cross format plug-in for Windows, macOS, and Linux, that supports AAX, VST3, VST and AU.
The 32C Channel Plug-in features the legendary Harrison 32C four band parametric equalizer with proportional Q... bell and shelving curves on the high and low bands... and musical overlapping midrange bands.
A High Pass and Low Pass filter section is included .... with a unique BUMP feature providing classic low end punch.
Harrison's innovative compressor with three different characters is also included. Selections for smooth compression... classic leveling... and fast limiting are provided.  Those 3 quick presets help you to recreate the signature compression effects with minimal effort.
The signal path through the 32C Channel Plug-in can be arranged via the routing section, providing the optimum signal flow for your project.  You can quickly audition any processor, or combination of processors, in the chain.
Input and output level controls are provided along with a VU style output meter for critical level management throughout.
Pricing and Availability:
$49 from August 17th through August 31st (MSRP $89 / MAP $69)
More information:
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
