Tick Metronome Metronome Plugin by Tal Aviram
2021-8-17 09:35| ·¢²¼Õß: 5289190| ²é¿´: 935| ÆÀÂÛ: 0
ÕªÒª: Tick is a self-contained metronome. It runs almost anywhere. It runs as a plug-in, it runs on your phone. Everything is self-contained so your metronome sounds (and your BPM/time-signature) can go whe ...
Tick is a self-contained metronome. It runs almost anywhere. It runs as a plug-in, it runs on your phone. Everything is self-contained so your metronome sounds (and your BPM/time-signature) can go wherever you go.
Features:
Sample-Accurate Metronome.
Customizable - You choose exactly how your metronome sounds. Including ability to do basic edits within Tick.
Portable - Tick is self-contained. As a plug-in, your audio samples are saved in the preset that is part of your audio session/project.
Low Pass Filter - avoid bleeds while recording.
Cross-Platform - Tick is available as an audio plug-in or a standalone app for Mac, Windows & iOS. Linux & Android (coming soon).
Open-Source - Tick is fully open-sourced so anyone can contribute.
Open-Standards - Tick preset format is a zip archive with plain WAVE files (containing metadata) along a simple readable XML.
Source Code Available at: github.com/talaviram/Tick
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
